Discussion stats
  • 3 replies
  • 1784 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
R7000 Router random dropping intenet to imac even though hardwired
help please...i am randomly losing my internet connection and losing my network connection but only on my imac.
The imac is hardwired by the way
Ive tried apple support and they cant see anything wrong with the imac
i tried resetting the router and that worked for about 3 weeks..its started to happen again though
every other device on the network is stable
ive changed switches, ports, cables etc..nothing worked apart form the reset
Cant decide if its the router or the imac??
Any ideasplease???
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Highlighted
NETGEAR Employee Retired
Re: R7000 Router random dropping intenet to imac even though hardwired
Welcome to the community, @KevB46
If you bypass the router, will you have a stable connection?
You may want to try that out in order to further isolate.
Is there another device that's using wired connection on the router? Is it stable too?
Another thing you may do is to use Address Reservation feature on the router.
ElaineM
NETGEAR Community Team
Message 2 of 4
Highlighted
thx Elaine
im not sure what you mean by "bypass the router"?
yes there are tvs and a pc that are wired and all seem stable
hard to know for sure because the mac does most of the work but i would say so
adress reservation is a static ip adress? if so yes i tried that previously
Message 3 of 4
Highlighted
Connecting the computer directly to the modem.
That's a strange scenario you have there.
Maybe borrow a different router or reinstall the OS?
ElaineM
Message 4 of 4
