Reply
R7000 SLOW Wired/LAN -- Need Help
rafakoy
Initiate
I recently upgrade my internet conection from 150/150Mbps to Gigabit (Verizon FIOS).
My router is a Nighthawk AC1900 (R7000). My two desktop computers are wired and I use Wifi only for phones, a laptop, Xbox, Tv, Roku, etc.
Before the service upgrade, speed was never a problem with 150Mbps, the router always gave me maximum wired speed with my desktop computers, now with the new service, I only get around 350 Mbps but if I connect the fiber optic Verizon modem directly to my PC, I get around 980Mbps. What's going on? Doesn't the R7000 supposed to be Gigabit for wired conections? I tried everything, I read all forums, disabled QOS, changed MTU packages sizes, reset the router, etc. but nothing works. I use Cat 5e cables.
I'm starting to think the Gigabit statement from Netgear is a big BS.
This is the speed I get if I connect my computer directly to the modem:
And this is the speed I get if I connect (wired) to the R7000 router:
I'm not concerned about the Wifi speed, and I'm also not asking to get exactly the same speed I get with a direct connection, but that's a huge difference.
Any ideas?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 6
Accepted Solutions
rafakoy
Initiate
Re: R7000 SLOW Wired/LAN -- Need Help
I was able to get full speed (around 930 Mbps) with the R7000, however, after spending hours with the router I can say without doubt, it's an unreliable router for Gigabit conextions. After a factory reset I get full speed, but if I attempt to make any change on the configuration of the router after that, like setting parental controls, etc, the speed automatically goes down to ~300Mbps. Bottom line, if anyone has problem traying to get Gigabit speeds with the R7000, do a hard reset and do not attemp to make any change in the configuration of the router other that WiFi names and passwords.
Message 5 of 6
All Replies
sktn77a
Virtuoso
Do you have the WAN to LAN specification for the router - I suspect that is nowhere near the LAN to LAN speed (1000Gb/s)
Keith
(2xWNR2000, 3xWNCE2001, FWAG114, FS116, GS116, 6xR7000, EX7000)
Message 2 of 6
sktn77a
Virtuoso
Never mind.  I just found this reference indicating that the WAN to LAN speed is close to 1 Gb/s.
https://www.smallnetbuilder.com/wireless/wireless-reviews/32239-ac1900-first-look-netgear-r7000-a-as...
Keith
Message 3 of 6
Guru
Some users have reported that the R7000 and R8000 routers don't work well on Gb ISP speeds. Others have reported the the R7800 does.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 4 of 6
rafakoy
Initiate
Message 5 of 6
Guru
So if you make a change to any other area, the speeds drop? Interesting. Something NG should be made aware of. Seems like once a configuration is done, something maybe disabling the HW acceselerator.
Testing
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 13454 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
