- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 (Speed is less than half compared to Verizon router)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for any help
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 (Speed is less than half compared to Verizon router)
AP mode disables hardware acceleration. Try connecting the R7000 to the network through one of its LAN ports. This will bypass the slow path between the WAN and LAN ports. IOW, don't use the WAN port. You may lose the ability to log into the R7000. Just reconnect the WAN port when you need to log in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. To answer your prior question, running it in router mode will also work but you have to disable the DHCP server. There's no need to do this; as you have already seen, it also works in AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also having the same issue just got Verizon fios gigabit internet an having that same problem can you please explain to me what you did to fix it thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
