Discussion stats
  • 5 replies
  • 8164 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
R7000 Temp??
Can I view the temps in the stock firmware, If so how??
Message 1 of 6
Highlighted
Virtuoso
Re: R7000 Temp??
You can do that if you can get telnet to the router going. This command will give the country temperature :
cat /proc/dmu/temperature
And there is a way to get the radio temperatures that I forget at the moment.
But first you need to get logged into the embedded Linux in your router.
Message 2 of 6
Highlighted
Virtuoso
Re: R7000 Temp??
I hate spelling correction...I typed the above on my iPad, and it corrected "CPU" to "country" somehow. This should say that the above command will give the CPU temperature, not the "country" temperature *sigh*.
Sorry.
Message 3 of 6
Highlighted
Re: R7000 Temp??
How do i get telnet going on the new firmware & on windows 7?
Message 4 of 6
Highlighted
Re: R7000 Temp??
I put ddwrt on it yesterday to get the temps & flashed it back to stock. Today I replaced all the stock thermal pads with Fujipoly Sarcon XR-m with thermal Conductivity of 17 W/mk. Tonight I'll flash ddwrt back to it and get the temps and compare.
Message 5 of 6
Highlighted
Re: R7000 Temp??
Here are the results of my test, some of you overclockers might be interested.
Stock Thermal Pads:
Fujipoly Sarcon XR-m Thermal Pads:
Message 6 of 6
