Reply
R7000 Trouble reconnecting device
Joanne16
Follower
Streaming video from dvd player quit working. Says it is not able to connect. Tried the firmware update. Ran the Ios download(?). The device is asking to enter the security key or the WPS(PIN). Okay, Im clueless. What are either of these and how do I find them? Thank you.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
IrvSp
Master
Re: R7000 Trouble reconnecting device
You are using WPS to handle the connection between Router and Device.  To see the number to enter on the device you must open the Router via an Browser and select the ADVANCED tab on the top row. Then ADVANCED SETUP and WIRELESS SETTINGS should be clicked. At the BOTTOM of the page you'll see the WPS settings and the CODE to enter. It might also be on the label on the bottom of the router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2150 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
