Orbi WiFi 7 RBE973
Reply
R7000 USB 3 / ReadyShare not working
SalAKhan
R7000 with V1.0.8.34_1.2.15 firmware.
Have a Seagate Expansion 5TB drive that works fine on the rear (2.0) port but not on the front (USB 3) port.
A generic USB FlashDrive works fine on the front port.
From a search it seems this STILL hasn't been solved?
Need a solution.  Thank you.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Accepted Solutions
SalAKhan
Re: R7000 USB 3 / ReadyShare not working
Solved:
Format drive in NTFS with Default Allocation
Factory Reset router with latest firmware.
Seems to work now.
Message 2 of 2
All Replies
SalAKhan
Solved:
Seems to work now.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4180 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
