- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
R7000 - Unable to connect to 5G after Firmware Update V1.0.9.34
Has anyone experienced issues with 5G connectivity after updating to firmware version V1.0.9.34? I updated the firmware and can no longer get a connection to the internet using 5G (5G network shows available, but no "internet connection"). Potential defect of the the recent release?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R7000 - Unable to connect to 5G after Firmware Update V1.0.9.34
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
A similar complaint is HERE. Not exactly, but close. Probably something common to your setups possibly?
There is no '5G network'... you have a LAN, both the 2.5Ghz and 5Ghz are SSID radios for connection to that LAN. So, does the devices on the 2.4Ghz SSID have Internet?
As a test, could you rollback to the old firmware you were using, RESET the router, manually reenter the settings and see if you still have problems?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes, having the same issue. Was fine before the firmware update.
Devices connect okay but report as having no internet connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Have you tried resetting the router? Also, you could try re-booting your modem, then reboot the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
