Reply
R7000: Using an external drive with a powered usb hub
GeorgeSully
I can connect a WD Passport drive into the 3.0 USB connection and see it fine. If I plug a powered USB hub into the 3.0 and then plug thumb drives and the Passport drive into it, I can see the thumb drives OK but I cannot see the Passport. Normal? Setting to correct? Something else?
Message 1 of 6
Retired_Member
Not applicable
Re: R7000: Using an external drive with a powered usb hub
Does the USB hub have its own power?
Message 2 of 6
Retired_Member
Not applicable
Nevermind, I see now that you said in the title it is powered. Is the drive self-powered or is it pulling power via USB?
Message 3 of 6
GeorgeSully
Yes. It is a 3.0 powered hub.
Message 4 of 6
GeorgeSully
The drive gets its power from the USB connection.
Message 5 of 6
Retired_Member
Not applicable
Make sure the drive is self-powered, that could be an issue.
Also, try unplugging all of the other drives from the hub, in case you may have hit some kind of device limit on the port.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2476 views
  • 0 kudos
  • 2 in conversation
Announcements
