- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000-V1.0.5.52_1.1.81.chk
- Mark as New
- Bookmark
- Subscribe
- Permalink
I stumbled on this FW today and was wondering if anyone @ Netgear cared to comment on it.
It's 12KB larger than the .48
Dated 12/21/2015
Has all the options that .48 had from what I can tell
Confirmed Port Forwarding does work for QNAPCLOUD
Faster file transfers from LAN to WiFi @ 866.7 peaked 74MBps averaged mid 60's
Connection rates 866.7~780.0MBps
A 7.73GB file now tranfers in UNDER 2 minutes.
I am able to ping and reach my gateway @ 10.0.0.1 which I couldn't with .48
Seems like a winner so far.
Good JOB!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
dBm levels should read -26 & -25
As a comparison to r8000 5g -38 2.4 -28
A 7.73GB file now tranfers in UNDER 2 minutes (mid 60's MBps) with r7000 ....R8000 takes over 2.5 minutes @ an average of 50MBps
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000-V1.0.5.52_1.1.81.chk
iPhone 4s Speedtest now hits 52MBps which is a first, and is better than mid 30's with r8000.
R7000 2.4 and auto channel in case your wondering
Signal (dBm) is 26 5g @1300 and 25 2.4 @ 289 These are back to the levels the r7000 had when first released more than 2 years ago
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's the FTP link. It's slow at moment
ftp://download.netgear.com.cn:8084/R7000/R7000-V1.0.5.52_1.1.81.chk
- Mark as New
- Bookmark
- Subscribe
- Permalink
Loaded and running perfectly so far! File transfers fastest I have ever seen.
Does anyone know if this has the laest Broadcom drivers?
CC
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not seeing it on the router updater or netgear website yet, wat was that other link you sent?
- Mark as New
- Bookmark
- Subscribe
- Permalink
netgear admin will post as new beta fw soon
- Mark as New
- Bookmark
- Subscribe
- Permalink
The link in post 16 is working. What's the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No I said netgear admin will soon post as new beta fw. Nothing to be reported. If there are some changelogs which we can expect them to update .
- Mark as New
- Bookmark
- Subscribe
- Permalink
new version has been released
check your router update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Running it now and it added an Arlo tab for web cams. Seems to be ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't run stock firmware in such a long time, but I may load this on of my 7000's. If anyone runs this FW in AP mode, can you check to see if NTP works?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm sort of confused at the moment, so we have a beta firmware which is V1.0.5.52 which looks to be really good then now we have 1.0.6.28 which doesnt seem to be as good? XD I would have thought 1.0.6.28 would have included everything V1.0.5.52 had
- Mark as New
- Bookmark
- Subscribe
- Permalink
Runs well. The added support for the Arlo cameras works great - means I can use the R7000 as the base station and ditch the other hardware that came with the cameras.
