- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
R7000 V1.0.7.10_1.2.3 and V1.0.7.12_1.2.5 OpenVPN cannot connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 V1.0.7.10_1.2.3 and V1.0.7.12_1.2.5 OpenVPN cannot connect
I do not know. I have never had to reset one. Easy enough to check after reset. Just logon and look.
Suggest you get your router reset and updated and working with the most recent firmware before starting on the VPN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Factory Reset solved this issue, but not without a couple of small hiccups (unexpected behavior). Here is an abbreviated listing of steps I took:
R7000 Reset
Minor config changes like router pwd change, DHCP Range update, Dynamic IP setup, OpenVPN setup D/L OpenVPN config files to laptop (still running: openvpn-install-2.3.14-I601-x86_64.exe)
Verified that R7000's firmware has NOT changed: V1.0.7.6_1.1.99
Tested OpenVPN connection - SUCCESSFUL
Updated Laptop OpenVPN to: openvpn-install-2.4.1-I601.exe
Updated R7000 firmware to: V1.0.7.12_1.2.5
Setup Control Access entries on R7000
*** After setting some actively connected devices to "Allowed", I turn on the option "Block all new devices from connecting" (it was defaulted to "Allow all new devices to connect" )
Setup Static IPs for four devices (Reserve IP Address)
Powered on two devices identified as having Static IP
*** Noticed Static IP rules are NOT being followed
Tested OpenVPN connection - NOT SUCCESSFUL
*** A line trying to open the router's ip address (192.168.1.1) keeps repeating
I turned on the option "Allow all new devices to connect"
unsure if I did anything at this point, but it was not anything major
I turn on the option "Block all new devices from connecting" (expecting the OpenVPN connection to possibly fail, again)
Tested OpenVPN connection - SUCCESSFUL (UNSURE why this did not work earlier)
Powered off two devices identified as having Static IP
Rebooted R7000
*** Verified Static IP rules are now being followed (UNSURE why this did not work earlier)
With
o R7000 firmware: V1.0.7.12_1.2.5
o OpenVPN from: openvpn-install-2.4.1-I601.exe
One last note: I did notice my ISP's assigned IP had changed after the R7000 reset to something totally different than for the past three+ years. Unsure if the ISP's IP address to my home changed during the same time I originally upgraded R7000 to V1.0.7.10, which is when I noticed OpenVPN not connecting, and/or whether the Dynamic IP service failed at the same time, or a combination. But just wanted to point this out.
Thanks everyone for the help, especially Kitsap.
If anyone likes to comment on the small hiccups (unexpected behavior) above and/or the change in ISP assigned IP address, feel free.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just one note - someone had taken it that my OpenVPN is now up-and-running, but intermittently. In case anyone else have misunderstood me, let me clarify that this is not the case; rather, the hiccups I encountered was only during the initial Restore-to-Factory post above but have went away (without an explanation).
I am however going to test this new setup over the next week or two, and if all goes well, I will proceed by classifying this thread as "SOLVED". Until then, I will leave it as is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Marking this as RESOLVED. All seems to work now. It appears one of the previous firmware upgrades somehow resulted in the OpenVPN Server not working.
- « Previous
- 1
- 2
- Next »
