Reply
R7000 V1.0.9.42_10.2.44 WiFi Slow
Nodistortion
First time poster to the community. I mainly use the R7000 for a wireless AP.  Recently updated the R7000 to V1.0.9.42_10.2.44, performed the hardware reset and re-entered the info manually.  The Lan connection is almost the same speed as my 100Mb internet connection, but when I try to use the 2.4Ghz and 5.0Ghz I am lucky if I can get 5Mb download speed consistley.  I have had the WiFi slow down with previous firmware updates and usually the next update clears it up.  I am open and looking for any suggestions, but it sure seems like there is a problem with this version.  Thanks in Advance
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
DarrenM
NETGEAR Moderator
Re: R7000 V1.0.9.42_10.2.44 WiFi Slow
Do you have smart connect enabled? if so try to disable that feature.
DarrenM
Message 2 of 5
Nodistortion
The Enable Smart Connect is unchecked.  Thanks   Jim
Message 3 of 5
tim_seven
Looks like there is a new firmware version.  1.0.9.60_10.2.60
Does it fix your problem?
Message 4 of 5
Nodistortion
Yes sir, the new firmware 1.0.9.60_10.2.60 is working much much better with WiFi, the speed is now limited by my ISP service speed.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 701 views
  • 0 kudos
  • 3 in conversation
Announcements
