Orbi WiFi 7 RBE973
R7000 Vulnerability - When will new firmware be released to address this?
RSM52
Tutor
ZD Net is now recommending that we shut down our R7000 routers until Netgear generates a fix to the exploit code that was recently released.  As shutting down a router is not a reasonable option I would like to know when Netgear intends to address this issue.  It should be now.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 10
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: R7000 Vulnerability - When will new firmware be released to address this?
Message 10 of 10
All Replies
microchip8
Master
Knowing NG, it can take a few weeks or up to a month
Message 2 of 10
mPresto
Initiate
You may not neet to shut down your router. Came across this blog describing a simple temporary fix:
www.sj-vs.net/a-temporary-fix-for-cert-vu582384-cwe-77-on-netgear-r7000-and-r6400-routers/
Basically it describes killing the http server process ( using the vulnerability to do so of all things). Rebooting the router will start the http process again.
Hope an update will be available soon. I just bought my R7000 and was rather disapointed to hear this.
Message 3 of 10
TheEther
Guru
Netgear has acknowledged the vulnerability.
http://kb.netgear.com/000036386/CVE-2016-582384
Message 4 of 10
mdgm-ntgr
The Security Advisory has been updated with more information and beta firmware for some models. Thanks for your patience.
Message 5 of 10
Atrum
Initiate
I use an ARLO compatible version on my R7000, will there be an update to correct this vulnerability?
Is there already a beta version correcting the vunerability with ARLO support on the R7000?
My current firmware is the R7000-V1.0.6.40_1.1.90
Message 6 of 10
copyer
Message 7 of 10
mdgm-ntgr
Arlo support was removed from R7000 firmware a while back now.
You can use an Arlo base station with your cameras. You can even use the new Arlo Pro base station which has a siren.
Message 8 of 10
Atrum
Initiate
I invested in a camera arlo without base station because you praised the possibility of using arlo with the R7000.
That you no longer support ARLO for the R7000 is one thing, but you need to fix at least an older firmware supporting ARLO by fixing the vulnerability. I'm not the only one to still use an old firmware compatible ARLO!
Message 9 of 10
ElaineM
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 5141 views
  • 6 kudos
  • 8 in conversation
Announcements
Orbi WiFi 7
