Reply
R7000 WAN Port Not Working - Use LAN as alternate?
enzestef
can someone give details instruction on how to do use one of the 4 LAN port for the internet if the WAN port not working. Thank you
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 6
Retired_Member
Not applicable
Re: R7000 WAN Port Not Working - Use LAN as alternate?
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
read them several times and then read them again on second thought the router is already toast so no big deal just go slow
I used this 3rd party several times without a problem
Message 2 of 6
enzestef
Thank you for the quick response, but im not a hightech guy, do i need to connect the router to a computer to do this download? what port do I use? can the Netgear tech support help with this? tks
Message 3 of 6
Retired_Member
Not applicable
You're Welcome,
How old is router if over a year no support if under a year and registered go MYNETGEAR.com contact support and have it replaced.
This is a 3rd party FW NO support from NG
download file to desktop and connect router lan port 1~4 to PC ..login and go to update router
Message 4 of 6
enzestef
The router is 18months old, netgear said thay cant do anything and i need to buy a new one, thanks for the instruction i will try it.
Message 5 of 6
Retired_Member
Not applicable
Just take your time the procedure is well written.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3307 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
