Reply
R7000 Web Interace failing
Bunky927
I've noticed that my web interface in my Nighthawk R7000 is periodically failing "Unanle to open webpage" from browser and via the app "Your Router is not supported". To fix this problem, I have to reboot the router. Is there a fix?
R7000
Firmware V1.0.5.70
Version 2.4.24
Message 1 of 14
vango07
Re: R7000 Web Interace failing
I am having the same problem. It started today and I tried to reset the router several times but I cannot access it. Genie says that the router is not found. If anyone has suggestions please let me know.
Message 2 of 14
Retired_Member
Not applicable
Try a factory reset to defaults and or a earlier FW version
@Bunky927 wrote:
Message 3 of 14
vango07
I already did the hard reset several times, and uninstalled Genie on all my devices. So a huge no-go, cannot find router and cannot access the router at all. I am able to use the net, but I cannot set up my networks and passwords. Any help will be appreciated. Thanks.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 4 of 14
Retired_Member
Not applicable
The genie app has been known to cause problems, I consider it bloatware and do not use it.
A factory default reset done correctly and a Clean PC with IE and cache cleared should work, If not you're the exception and will have to get use to it or replace it.
Un-installing genie may or may not be enough if the device has a corrupted OS.
Message 5 of 14
vango07
Is there a way to reinstall the OS on it? I don't feel like spending a couple of hundred dollars on a new router.
Message 6 of 14
Retired_Member
Not applicable
The os comment was directed toward the PC.
If you open a browser and type the gateway address what happens?
Message 7 of 14
vango07
Sorry brain is fried trying to figure this out. But I type in the router login and nothting. I type in the IP and same thing. I've done factory reset about 6 times now. I have also uninstalled Genie app on 2 different computers (1 desktop, 1 labtop) I am not able to access the router at all.
Message 8 of 14
Bunky927
When I power cycle mine, the web interface is available. But I guarantee after a few days, it will not be accessible again.
Message 9 of 14
Bunky927
From a browser I get "page not found". When I power cycle the router, I can access the web interface
Message 10 of 14
Retired_Member
Not applicable
to both of your what FW versions
Kaspersky anti virus has been found to block connection to the r7000.....if you're using it DELETE it
Message 11 of 14
vango07
I am using AVG pro. I recently switched to Grande internet, and I'm wondering if the new modem could be blocking it.
Message 12 of 14
vango07
I've done that a ton of times and no luck so far. Still no wireless router access.
Message 13 of 14
JamesGL
Master
Hi All,
Make sure to update the router's firmware. Please check the support site for firmwares.
http://kb.netgear.com/app/answers/detail/a_id/30955
JamesGL
Community Team
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2290 views
  • 0 kudos
  • 4 in conversation
Announcements
