Reply
R7000 Wifi issues
lenzini
R7000 Wifi issues
Is there anyway of increasing reception with this router. I use BT Open zone when staying in our caravan so have no way to increase signal at source. The signal is ok when used in open window but only viable in good weather.
Can an external aerial be used to increase reception? Any otherway to solve proble?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
storm1985
Prodigy
Re: R7000 Wifi issues
connect wifi extenders
Message 2 of 4
lenzini
These all seem to boost signal after the extender. Is there anyway to boost the signal comming into this extender as the wifi point is a few 100 yards away and I can only receive in direct line of sight without any obsticles. I have no option to boost  signal in between source and booster. Are all 3 aerials used for transmition?
Message 3 of 4
storm1985
Prodigy
check these devices. These are business APs where you can connect external antennas. You may contact support to check what models with external antenna and what model of antenna supported as well.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1609 views
  • 0 kudos
  • 2 in conversation
Announcements
