Orbi WiFi 7 RBE973
Reply
R7000 auto channel selection
clauser
I would like to know when the channel selection of the R7000 occurs when set to 'auto'. Does it only happen at startup or does it also happen when the R7000 is up and running?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: R7000 auto channel selection
Hi clauser,
It will automatically change once the router detects a channel is being used by different router or if the channel is congested.
Message 2 of 5
All Replies
JamesGL
Master
Hi clauser,
Message 2 of 5
JamesGL
Master
Hi clauser,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 5
clauser
I don't need any further assistance. The answer you gave was very useful.
Thanks for the support.
Message 4 of 5
JamesGL
Master
Hi clauser.
Thank you for the feedback. We encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 7381 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
