Reply
R7000 behind Uverse 5268AC
txan
Follower
Our new AT&T Uverse 5268AC modem is stepping on the previously used R7000 static IP reservations. I don't see how to disable DHCP on the 5268AC and ATT tech support is no help. I want to continue using the R7000 IP reservation table and WiFi and simply get internet from the 5268AC.  Has anyone faced this issue and resolved it?
thank you!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
TheEther
Guru
Re: R7000 behind Uverse 5268AC
Enable IP Passthrough on the 5268AC and point it at your R7000.  Setup is similar to the NVG589 (link).
You should also change the 5268AC's subnet to avoid the conflict.  You can change it to 192.168.2.0/255.255.255.0 for example.
Message 2 of 2
Discussion stats
  • 1 reply
  • 3484 views
  • 0 kudos
  • 2 in conversation
Announcements
