Reply
R7000 - can not connect to laptop
Myhero
Follower
I’m trying to connect a new laptop and I am being asked for the network security key. I have entered my WiFi password, I’ve entered the security key that is on the bottom of the router, I have unplugged and plugged it back in. None of these have worked.
I called Netgear and there is no option to actually speak to a person for help. I am hoping that someone here can help me.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Guru
Re: R7000 - can not connect to laptop
have you logged into the router to check/confirm the ssid and password?
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 99 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
