Orbi WiFi 7 RBE973
Reply
R7000 cant access my security cameras
Cmnessler
I have 2 security cameras installed on my network, but I am unable to access the feed on my phone when my phone is not on the same network. I have been informed by the camera company that this is happening because of a firewall on my router not allowing outside devices to access devices on my network. Does anyone know how I can disable the firewall for these devices? I have been searching for an answer and have come up empty.
Message 1 of 12
Accepted Solutions
Cmnessler
Re: R7000
I hope you have a great day antinode. I shall take my ignorance and stupidity elsewhere.
Message 10 of 12
All Replies
antinode
Guru
Re: R7000
> I have 2 security cameras [...]
   Not a very detailed description of anything.
> [...] I have been searching for an answer and have come up empty.
   "searching" for what, exactly?
> [...] Does anyone know how I can disable the firewall for these
> devices? [...]
   A typical way is to create a port-forwarding rule.  With no actual
information on your "2 security cameras", it's tough to be specific.
How do you deal with them on your LAN?  Web browser?  Some app or other?
Message 2 of 12
Cmnessler
Re: R7000
There is no need to be so passive aggressive - it helps no one.
The type of security camera is irrelivent. I am only looking for a step by step guide to disabling the firewall so I can view these cameras when I am away from my home network, which these cameras are connected to. I have been ‘searching’ for this step by step guide online. I view the camera feeds through an app.
Message 3 of 12
antinode
Guru
Re: R7000
   Passive?  There is no need to be so stingy with useful (or required)
information, either.  If you insist on treating simple, relevant
questions as intrusive or unimportant, then it'll be very tough to make
any progress.
> The type of security camera is irrelivent. [...]
   And you know this how, exactly?  If you could distinguish between
relevant and irrelevant in this context, then you likely wouldn't be
here asking (information-free) questions like this.  (And wearing out
your welcome with someone who might be able to help, if given a chance.)
> [...] I am only looking for a step by step guide [...]
   Please let us know if you find one.
> [...] to disabling the firewall so I can view these cameras when I am
   That's not how it works.  You have a NAT router; the "firewall" is
implicit in its operation.  You can configure (port forwarding on) the
router to allow incoming connections to any device(s) on your LAN.
Sadly, however, that requires some actual information about which
external ports to forward to which internal ports at which IP addresses.
That is, actual information about how your (unspecified) cameras work.
> [...] I view the camera feeds through an app.
   I wouldn't want you to wear yourself out with exhaustive detail, but
it might help to know how this (unspecified) app identifies/locates a
particular camera.
Message 4 of 12
Cmnessler
Re: R7000
Thanks for your input. I was only looking for help - not a lecture. If you have nothing more productive to add, I will look for another individual to help me. Thank you and have a fabulous night.
Message 5 of 12
antinode
Guru
Re: R7000
> [...] I was only looking for help - not a lecture. [...]
   Ok, but you seem not to understand the problem.  Hence my attempt at
education, hopeless as it may have been.
> [...] If you have nothing more productive to add, [...]
   Without any useful information, there's little that I can do.
> [...] I will look for another individual to help me. [...]
   I wish you the best of luck in your search for a psychic with IP
networking knowledge.
   My car won't run.  I have been informed by the car dealer that my
filters are defective, but I can't find them.  I have been searching for
an answer and have come up empty.  The make and model of the vehicle are
irrelevant, and I won't answer any other questions.  Please help me.
   With that attitude, you may need more than luck and "another
individual".
Message 6 of 12
Re: R7000
I'm afraid this displays a misunderstanding of how many of these things work.
Firewalls are almost certainly not a part of the story.
Just because a camera maker mutters about firewalls does not mean anything. It would not be the first time that a pig ignorant support person has got things wrong. ISPs are especially good at blaming router makers for things that turn out to be issues on their networks.
In any case, there is not much that you can do with what passes for a firewall on a Netgear router.
It really does depend on the cameras and how they need to be configured to use things like different ports on a router.
If you aren't prepared to tell people what the cameras are, there isn't much that they can do.
Look back at your first message and ask tyourself how much useful information it tells us. Is it any wonder that you canlt get sensible responses?
I assume that you have thrown  the make of camera into the search engine here. Many of these issues have come up before. There may well be useful tips out there somewhere.
Message 7 of 12
Cmnessler
Re: R7000
I would have been more than happier to give more information to the original commenter, had he not been such a troll about it. I was only seeking help. But when I am attacked straight away for my “ignorance,” you can understand why it’s difficult to be forthcoming with more information. Have a great day.
Message 8 of 12
antinode
Guru
Re: R7000
   That depends on how you define "Firewalls".  A NAT router
intrinsically provides a type of "firewall" by blocking incoming
connection attempts.
> [...] But when I am attacked straight away for my "ignorance," you can
> understand why it's difficult to be forthcoming with more information.
   "attacked"?  "ignorance"?  Where?  How does an adamant refusal to
provide basic, required information contribute to solving your (network)
problem?
   There's abundant evidence that you _are_ ignorant, but that's not the
problem.  The problem is that you're uncooperative when asked for basic,
required information.  Generally, ignorance is easily overcome;
stubbornness (or stupidity?) is a different problem entirely, and may
present an insurmountable obstacle to progress.
Message 9 of 12
Cmnessler
Re: R7000
Message 10 of 12
colinsieff
Nighthawk AC1900
Hi have several issues with a bluesound WiFi speaker dropping and regaining connection repeatedly. But now a more urgent question is that the R7000 keeps dropping the internet connection, even though it looks like it is connected on the MacBook Pro menu bar (black filled inwireless symbol with correct name of internet checked). Have to reboot and then hold connection for a few minutes to a few hours. It is connect by a bridge to a Verizon quantum with  WiFi disabled and worked ok for months. I'd appreciate any help. Thanks.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 11 of 12
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk AC1900
What firmware version are you on? try to load the .42 version and see if that helps.
https://kb.netgear.com/000060253/R7000-Firmware-Version-1-0-9-42
DarrenM
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 4794 views
  • 1 kudo
  • 5 in conversation
Announcements
Orbi WiFi 7
