- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 drops 5GHz when brother drives away!
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Nest camera has confirmed this numerous times.
1. My brother gets in his car and drives away
2. Camera goes offline
I noticed this several times recently. Today I figured out that the disruption affects only 5GHz connections. WIred connections and 2.4GHz WiFi operates normally with no disruption.
This time the 5GHz interruption cleared itself after 22 minutes. I did not reset anything, but I maybe it kicked something when I logged-in to the web setup and checked for updated firmware. The router's internal web page reports that it's currently using "V1.0.9.88_10.2.88" firmware and no update is available.
The device my brother is carrying when he drives away is a Samsung Galaxy Note 9.
I found discussions suggesting that I downgrade to an older firmware to prevent random 5GHz disruptions. I don't know if they ever discovered a correlation to a client device leaving the network range. Maybe this observation will lead to a proper fix or work-around without installing an out-dated / insecure older firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 drops 5GHz when brother drives away!
> [...] The router's internal web page reports that it's currently using
Trust no one, I always say.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
