- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 extremely slow upload speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchased my Nighthawk AC1900 (R7000) and have been having issues with the upload speeds. I've edited QOS and restored to facotry settings. Yet, the problem still persists.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make your changes to the configuration slowly one at a time making speed checks between each change.
You won't ever need QOS with the speed of your Internet connection. Don't even turn it on because I have seen it give people problems like you had even after turning it back off.
Don't ever upgrade firmware unless it fixes a problem you are experiencing or it has a security fix you need. I kept my R7000 on 1.0.4.28 until 1.0.7.6 came out with security fixes. Every firmware change is a risk of corrupting or even bricking your router.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 extremely slow upload speeds
I also did the reset button on the back of the router. Still slow upload speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What speeds are you paying for and what are you getting?
Have you tried connecting your computer directly into your modem and testing it that way?
Are you using speedtest.net?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I pay for cox ultimate (up to 300mbps dl, upt to 30mbps ul). Download speeds is workig just fine, but upload is around 600kbps consistently. Even after factory rest, button reset, and rebuilding QOS settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using speedtest to test speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try doing a long reset by holding in the reset button until the power light turns orange and starts to blink and cycles through this three times, it will take about 30 seconds.
Then log into the routers web interface and change the admin password. Leave all other configuration items alone and test it with these defaults.
Use http://www.speedtest.net/ for the test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
After resetting and leaving SSID as provided, upload speed is back in the 30's. Do i have to keep the provided SSID that came with the router or can i change it now that the upload speed is back to normal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
