Reply
R7000 failed to set banned domain names and parental control
bing_mao
have set the banned domain names and parental control, it's much strange that some of the set rules work, some not; and sometimes work, sometimes not.
Smiley SadSmiley SadSmiley Sad
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 7
Accepted Solutions
schumaku
Guru
Re: R7000 failed to set banned domain names and parental control
The URL filter can't work on https connections.
LPC is DNS based, independant of the access protocol (like http, htps, ftp, ...), so it can cover.
Message 4 of 7
All Replies
schumaku
Guru
All using Netgear LPC, or have added domains/URLs to the URL filter? The later one can't work on secured/encrypted https sites.
Message 2 of 7
bing_mao
Thanks!
So LPC and URL filter are unavailable on https protocol?
Message 3 of 7
schumaku
Guru
Message 4 of 7
bing_mao
tried LPC just now, added a new domain "weibo.com", then reset R7000, but didn't work.
Message 5 of 7
schumaku
Guru
The client might have the domain cached, aside there are several related domains to fully block weibo.com (for example). Afraid, I have no LPC setup to check.
Message 6 of 7
bing_mao
Thanks a lot!
Yes, it's possible that domains are cached.
Another question: is it necessary to keep the software of router control running when startup(or reset) the router?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 763 views
  • 2 kudos
  • 2 in conversation
Announcements
