Reply
R7000 guest wifi no work
Rvhii
At one time (2014) the guest network functioned without issue.
now the guest network does not appear on an iPad, IPhone, or Dell laptop as a choice.
Have rebooted. The guest network is turned on in settings. Both the Bands are activated in setttings
the firmware is up to date.
Otherwise the router functions properly.
any ideas on what I'm failing to see? Or do?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
Retired_Member
Not applicable
Re: R7000 guest wifi no work
If the guest SSID is being broadcast and still can't be seen, then reset to defaults and reconfigure and or revert to earlier FW
Message 2 of 3
Rvhii
Thank you. Will try when I get back home.
IT101 (reboot) failed.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1948 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
