Reply
R7000 how to block remote management over WAN and WIFI?
PKComputex
Follower
Hi cant find option to block access to router gui from WAN and WiFi.
I want to be bale to access router GUI only from LAN.
Any ideas how to do it? I have this option on my old routers (Netgear, Linksys, Dlink) but on this one this is missing.
Best Regards
Message 1 of 2
Temporel
Novice
Re: R7000 how to block remote management over WAN and WIFI?
You didnt spent much time looking for the info I guess.
Go Under "Remote Management" (Advanced Tab/Advanced Setup)
WAN access is off by default and you can set an IP range on that page too.
Just give static IPs for the computers you want them to have admin access and make sure you set the IP range accordingly.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1950 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
