Reply
R7000 in Bridged Mode losing connection
alanrpusa
This topic seems to be fairly prevalent in this and other forums, however, I've not seem a resolution published from Netgear so looking for support on this.
- R7000 loses connection (yes, everything on the 7000 wired to the 7000's enthernet)
-Cannot reach the 7000 wirelessly from main WiFi as can be done when it is not malfunctioning.
-This failure occurs on current firmware and past 3-4 versions of firmware at least
-Router operated fine in Bridged Mode for over a year before it began losing connection regularly
-Yes it has been reset and manually reconfigured after each upgrade.
-Yes it can be fixed by restarting router.
Please advise if this problem is going to be fixed.
Thank you
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: R7000 in Bridged Mode losing connection
Have you tested the issue by reverting back 1 firmware and seeing if that still happens?
DarrenM
Message 2 of 4
alanrpusa
DarrenM
Ive been using the router on every firmware including the last version.  It didn't work then, or the one before that, and it doesn't work now.
Message 3 of 4
icatt23
Guide
It's the router disconnecting from the internet randomly.  It's been happening for years with no fix.  Should be recalled.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 480 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
