Reply
R7000 inference with digital microphines, restrict frequencies?
RonFromChurch
Follower
We recently purchased a R7000 dual band router at our church and after installation our three digital wireless microphones had terrible interference. I learned they operate in the same range as the router. I can tune a specific frequency on each microphone. Is there a way to restrict specific frequencies or a small range on the router to leave them open for the mics?
If not can I turn down the power or worst case turn off the 2.4 range on the router? The microphones were each very expensive and I need a way have the mics and router share the space so to speak.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
antinode
Guru
Re: R7000 inference with digital microphines, restrict frequencies?
> R7000 [...]
   Which model is it?  Look for "Model" on the product label.  Firmware
version?
> [...] I can tune a specific frequency on each microphone. Is there a
   If only there were some kind of "good book" which might provide the
answers to all your questions...  But wait!  It's a miracle!
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for
"Specify Basic WiFi Settings" and "Channel".  (Chapter 6.  Verses are
not numbered.)
   If you have actual frequencies, rather than wireless-network channel
numbers, then see, for example:
      https://en.wikipedia.org/wiki/List_of_WLAN_channels
> on the router? [...]
   Look for "Control the WiFi Radios"?  (Same chapter.)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 214 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
