Reply
R7000 - intermittently losing internet
scavdog
I have had my Nighthawk R7000 for about 2 years with relatively no issues.  The last 2 weeks I have been losing internet sporadically.  If I catch it immediately the router will not allow me to log in (read I cannot get a login/pw prompt) for 2-3 minutes post event.  At that poing I will have to reboot the router and things go back to normal.
Any ideas?  I am expecting this thing is ready to brick at any moment.
TIA,
Joe
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 7
Guru
Re: R7000 - intermittently losing internet
What firmware are you on?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 7
scavdog
V1.0.10.90_10.2.90
Message 3 of 7
Guru
the recent firmware is 1.0.11.123 for the R7000. I don't even see your version listed as a prior version.
If you do indeed have the R7000, try updating over a hardwired connection. Then do a factory reset and reinstall.
https://www.netgear.com/support/product/R7000.aspx
Message 4 of 7
scavdog
It's on autoupdate - go figure
Message 5 of 7
scavdog
Message 6 of 7
Guru
You can manually update it.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 277 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
