Reply
R7000 ipv6 tunnelbroker Ip protocol 41
RealRedHair
Hello!
Trying to set up ipv6 tunnel with tunnelbroker (hurricane electric). They require: If you are using a NAT (Network Address Translation) appliance, please make sure it allows and forwards IP protocol 41.
How to enable this?
Thanks
[Tunnel Broker] Is there a basic guideline on how to set up a tunnel?
  1. Visit our tunnelbroker.net site and log in.
  2. Once you log into the site, click "Create Regular Tunnel" and provide your IPv4 endpoint address and choose a preferable tunnel server location. (Note: Your IPv4 endpoint address should be displayed on the tunnel creation page)
  3. After you successfully create a tunnel, visit your tunnel's detail page and choose your OS type to get example configuration commands.
  4. Use the commands to configure your machine. Please remember, you must have 'administrator' privilege to configure your machine.
  5. Once you configure your machine, please browse sites like http://ipv6.google.com or http://kame.net to test your IPv6 connectivity.
*Two important notes:
  1. Your IPv4 endpoint address must be reachable via ICMP ECHO_REQUEST (Internet Control Message Protocol).
  2. If you are using a NAT (Network Address Translation) appliance, please make sure it allows and forwards IP protocol 41.
What is IP Protocol 41? IP Protocol 41 is one of the Internet Protocol numbers. Within the IPv4 header, the IPv4 Protocol field is set to 41 to indicate an encapsulated IPv6 packet.
Message 1 of 5
storm1985
Prodigy
Re: R7000 ipv6 tunnelbroker Ip protocol 41
Try this.
1. Enable Respond to Ping to Internet Port - Advanced > WAN Setup
2. Not sure if this is the port number for IP Protocol 41 but you can try. Port forward UDP port 3653.
Message 2 of 5
RealRedHair
Did all according the following post: https://community.netgear.com/t5/General-WiFi-Routers/How-to-configure-IPv6-using-tunnelbroker-net/t... but it still does not work IPV6. (:
Message 3 of 5
storm1985
Prodigy
Is the R7000 behind another router or is this connected to a regular modem only?
Message 4 of 5
RealRedHair
Before I used http://www.deepdarc.com/miredo-osx/ Teredo. But since my upgrade to 10.11 OSX it did not work anymore. Any suggestions are welcome.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3437 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
