Reply
Highlighted
Apprentice
Re: R7000 keeps losing 2.4GHz wireless connectivity
I didn't change my configuration lately. It was running stable for months. After FW R7000-V1.0.9.12_1.2.23 the problem started. The latest R7000-V1.0.9.14_1.2.25, updated yesterday, isn't solving the wifi 2.4 issue.
I have 3 SSID's, one for 2.4 and one for 2.4 guest and one for 5. It has nothing to do with the configuration. There is something wrong in the last 2 or more versions.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 51 of 434
Highlighted
Guide
@Westfa - Thanks for the insight on the wi-fi button - indeed that "light" is also a button!  I had not noticed.   Next time it fails I'll try that instead of rebooting.  However (fingers crossed) - I have not had a failure in several days after turning off the 5 GHz radio - thanks again to @Volstate for that discovery.
We agree the 5G trick is NOT a fix but a short term pain-reliever at best.  Hope to see another new firmware release soon...  I wonder if anyone who is still under warranty has filed a complaint with Netgear??
Message 52 of 434
Highlighted
Apprentice
I tried to detect a pattern to the WiFi dropouts, but it seems random. Sometimes I only have to reset it daily, but yesterday I had to reset it 5 times! Just before typing this, it was down again. It's come to a point where I'm seriously considering writing it off and getting a new one (not Netgear).
Message 53 of 434
Highlighted
Tutor
I installed V1.0.9.14_1.2.25 and starting getting 2.4 disconnects.
Solved the problem by changing the 2.4 Channel from 'Auto' to '11'.
Ever since I made that change, no disconnects.
Message 54 of 434
Highlighted
Apprentice
I tried that, but after a while it fails again. I've had it work for almost a week and recently it fails multiple times a day.
Message 55 of 434
Highlighted
Apprentice
I had the same problem but with 5ghz. I went back 4 firmware versions and it was still doing the same thing so I factory reset using the hardware button and so far 24hrs have passed and it's working fine.
Message 56 of 434
Highlighted
I've tweeted @netgear including a link to this thread. Doubt it will do anything, but if firmware breaks their device, they should prioritize a fix, don't you think?
Message 57 of 434
Highlighted
Did you previously try a factory reset in the HTML router interface and it did not help?  I had a similar experience where the hardware button reset seemed to do something more extensive than the software factroy reset...
Message 58 of 434
Highlighted
Tutor
i've been going through similar pains.  Tonight I will try to disable 5GHz and do a factory reset from the button over the web.  If that doesn't work, i'll try reverting firmware version and perform factory resets.
Message 59 of 434
Highlighted
Apprentice
No I hadn't tried it through the software.
Message 60 of 434
Highlighted
Apprentice
I received a link to a beta firmware -> from JamesGL
Am I the only one who received this beta?
This morning problems again. Devices still connected to 2.4 GHz but no trafic possible. After connecting to 5 GHz the smartphone was communicating again. 2.4 GHz was not working, all 2.4 devices weren't able to communicate. Switching guest off with the Genie app was enough to bring 2.4 GHz back to work again.
Message 61 of 434
Highlighted
I was contacted about trying the beta firmware as well. But it seems odd to me the version number is 1.0.9.13 and the date on the file is from October... This doesn't look like a new beta firmware but a previous release that was not made public. Strange right?
Anyhow I just moved from 1.0.0.96 to 1.0.7.12 last night. If that remains stable I'll give this "new beta" a try tonight.
At least maybe it's a good sign the netgear moderators are getting involved... Perhaps it's a sign they are starting to acknowledge the screw up in the recent firmware...
Message 62 of 434
Highlighted
Star
Let me join this club, just to make this issue more... public, instead of personal.
Since a couple of days, I'm having the same issue, without making any changes to the settings.
In an attempt to fix it, I did a soft reboot, hard reboot, factory reset, fw update (to V1.0.9.14_1.2.25); none of it made any difference
What I find strange, are the frequent messages like these, I find in the log every 15 minutes:
[Time synchronized with NTP server] Tuesday, Dec 12,2017 13:24:48
[Internet connected] IP address: [TYPPEXD], Tuesday, Dec 12,2017 13:24:48
Message 63 of 434
Highlighted
Apprentice
is normal, I have it for years....
Message 64 of 434
Highlighted
Star
Okay, thanks, didn't notice it happened 4 times per hour.
One other thing that I've noticed, is the strange behaviour in the 'Attached Devices'-list.
A device connected to 2.4GHz often just disappears from the list, while still being connected and having an operational wifi-connection. After some time, the connection gets lost, and can't get re-established for some reason. This happens with all kind of devices.
Message 65 of 434
Highlighted
I've noticed this is the first symptom of the problem... The wireless devices will disappear from the attached device list. When this happens, they tend to keep operating for a little while but eventually the wireless devices will stop working. In my case all devices disappear from the attached devices list and then the 2.4g ones fail and finally the 5.0g ones fail.
Message 66 of 434
Highlighted
Apprentice
That problem is exacly the same as I have: see earlier post:
"Devices still connected to 2.4 GHz but no trafic possible. After connecting to 5 GHz the smartphone was communicating again. 2.4 GHz was not working, all 2.4 devices weren't able to communicate. Switching guest off with the Genie app was enough to bring 2.4 GHz back to work again."
Can anyone confirm that version 1.0.7.2_1.1.93 or maybe a few versions older or one or two versions newer is stable??? I had 1.0.7.2_1.1.93 running for years without any problems. Never rebooted the router. I never updated until a few weeks ago. I want to know if returning to 1.0.7.2_1.1.93 and completely reseting the router will solve all the wifi 2.4 GHz problems. I know 1.0.7.2_1.1.93 was perfect for me. I even have a config backup file from that time. So is it worth to downgrade to 1.0.7.2_1.1.93 and never update again???
Message 67 of 434
Highlighted
Tutor
FYI, a couple days ago i did a software reset through GUI, this didn't make a different.  Last night I disabled 5GHz and haven't had any drops/symptoms.
Hoping this will get me by until hey fix everything.
Message 68 of 434
Highlighted
Apprentice
Just got the same problem again (FW: V1.0.9.14_1.2.25):
2.4 GHz devices had problems again. Very strange, a ping was giving a normal reply but accessing the webpage of the wifi ip-cam was not possible. Device was also not available as connected device in the netgear list.
All 5 GHz devices didn't had any problem, also listed as connected device.
After a short while my remote raspberry pi session (I was remotely checking the problem) was gone. At that time the 2.4 GHz devices came back and they worked again. After restarting my remote session with my pi I saw the webpage of my wifi ip-cam again so 2.4 GHz was working again.
Conclusion:
- 2.4 GHz devices are losing their connection
- a ping is still working, normal reply from device
- after a while it start working again
- maybe with a short disconnection of all devices because my remote raspberry pi connection was gone for a moment.
Message 69 of 434
Highlighted
I updated from 1.0.0.96 to 1.0.7.12 last night and I've been stable almost 12 hours now.  So that version seems to be working at least...
Message 70 of 434
Highlighted
I also received the link from James and flashed the "beta" firmware. Within an hour the problem persisted.
I really would like it if we could find a recent firmware file that works, so we could downgrade until Netgear figures out what happened. I don't really want to beta test firmware.
Message 71 of 434
Highlighted
Apprentice
Keep us informed!!
I am sure version 1.0.7.2_1.1.93 was working fine!! For years! So maybe 1.0.7.12 also! Maybe other guys can do this test too. I am 100% sure 1.0.7.2_1.1.93 was great. Please downgrade to 1.0.7.2_1.1.93 or 1.0.7.12 and reset with the switch on the back.
Message 72 of 434
Highlighted
Tutor
Sincerely last post I've turned the 5ghz off and it's been noticeably better, only one crash in 48 hours.
But I bought a dual band router. I'd quite like to be able to use it as such.
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 73 of 434
Highlighted
Add me to the list....
Updated the router a week or two ago.  Started dropping all 2.4Ghz devices.  Updated to the latest V1.0.9.14_1.2.25 and the problem persists.
I've had quite a few years of flawless service from this particular router.  I can't believe they let a problem like this linger on week after week.  Please Netgear, fix this ASAP!
Message 74 of 434
Highlighted
Apprentice
This morning again problems with my 2.4GHz devices. My IP-Cam web interface, not reachable. BUT VERY STRANGE: reply to Ping is still working. Also a NAS connected via a WiFi to UTP device, cannot open web interface.
Please try to ping the devices which are gone! And tell me if you have the same.
Turning WiFi down and on with the switch on the router solved it again.
Message 75 of 434
Top Contributors
Announcements
