MattAN's avatar
MattAN
Follower
Jan 09, 2019
R7000 not assigning an IP address to Polycom VVX201 VoIP phone
Hello, just recently was sent a VoIP by my employer, however I am unable to use it as it is unable to connect to the network.  The Polycom VVX201 from Vonage is not being assigned an IP address by the R7000 router I am trying to connect too.  I have adjusted a number of settings within the Netgear genie to no avail.  Please help for my sanity.  Thanks.
  • Are you able to assign the ip address manually within the VOIP phone settings like set it to 192.168.1.30?
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
