× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 51 replies
  • 3219 views
  • 3 kudos
  • 11 in conversation
Announcements
Top Contributors
Reply
Highlighted
R7000 not putting out the speeds
Long story short (hopefully)
Netgear R7000 Firmware Version V1.0.9.14_1.2.25
Speeds at my Xfinity Router 233/12 (1 pc directly plugged in)
Great fast speeds
I plug into the Netgear router and test the speed again on the Netgear QoS Setup (QoS is NOT applied yet)
239/12 (speeds do fluctuate, I know this) its still fast
I test Xfinity with PC plugged into the Netgear 126/12
I turn on QoS and speeds at PC 91/13  it gets worse.
Went back to keeping QoS OFF, plugged PC into Netgear, tested Xfinity 131/12
Still bad coming from Netgear with 1 PC plugged in and nothing else.
But Running a test at teh Netgear router, speeds are what I am suppose to be getting from Xfinity, it's just not pushing the speeds out to my network.
What now?
The last thing I should do, but really don't want to is a Factory Reset.
That doesn't make any sense, and that shouldn't be the fix.
I have Security cameras setup and Iwould have to reset them up again. Not that bad, but still a pain.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 52
Highlighted
Re: R7000 not putting out the speeds
Can anyone help?
I may just buy a Cisco router for Christmas...
WOW.
I'm surprised that no one replied to this.
2 Days later not one person and I am still having issues.
See the pic's
At the Xfinity router, as it goes into the Netgear Nighthawk, speeds are fantastic.
Speed test on tehcomputer plugged into the Nighthawk, is just a little faster than dial up
Message 2 of 52
Highlighted
NETGEAR Expert
Message 3 of 52
Highlighted
I already have the latest FW, as I alreay wrote at the begining of my Post
Firmware Version
V1.0.9.14_1.2.25
Message 4 of 52
Highlighted
NETGEAR Expert
Hi  Nightcrawler67.
It's a trial FW.
Thanks
Message 5 of 52
Highlighted
I will give it A try and update
TY
Message 6 of 52
Highlighted
After downgrading the Firmware to Firmware Version
V1.0.9.13_20171121_session
This is a test at the router
 238.50Mbps
 10.92Mbps
And this is a test on a PC plugged into the router.
Download Speed
124.70 Mbps
Upload Speed
10.53 Mbps
I mean, its fast, but something isn't right.!
If I plug my PC directly into the Xfinity Router, and not use the Nighthawk, I get those fast speeds, just not after the router
Message 7 of 52
Highlighted
NETGEAR Expert
Hi Nightcrawler67,
THanks for your result sharing.
Did you mean
238.50Mbps
 10.92Mbps
is from GUI speed test ?
and got worse result from LAN PC by runing speedtest ?
May I know the WAN config ? ex: PPPoE ? DHCP ?
Message 8 of 52
Highlighted
QoS is NOT enabled, I am just doing a test to check the speeds that the router is getting.
I do 2 tests, one from the QoS, enable Qos, and there is a speed test
Latest test result: (Thu Dec 7 02:00:53 2017 )
 239.31 Mbps 12.14 Mbps
I get those same speeds, similar, when I plug my PC directly into my Xfinity router.
DHCP
So anything plugged into the router is NOT getting the same speeds.
Why?
Message 9 of 52
Highlighted
Apprentice
I am seeing similar results with my R7000 running 1.0.9.14.  Internet seems stables, a few days now, no reboot or enabling/disabiling circle is needed.
However, my home cable Internet (DHCP) is advertised as 150/15.   I was getting that speed using 1.0.9.12, but couldn't leave Circle on with that firmware.  I now get speed tests (via QoS page, or via the Netgear UP iOS app) of 169/16.  However, when I use speedtest.net on any browser (wired or wireless) or via the speedtest.net iOS app (wireless) I get around 80/16.
So, it seems all traffic (not just wireless) is roughly halfed in speed for download.
Yes, I use QoS/WebTraffic and Circle.  Disabling Cirlce or QoS makes no different to speed.
Right now I am testing for stability, which it seems to be (thank you!  1.0.9.12 was not).
Thanks.
Message 10 of 52
Highlighted
Apprentice
So, as painful as it would be, I decided today to factory reset my R7000 running 1.0.9.14.  Upon reset, my wired and wireless went to full speed.  This is good news!
I am now turning items back on step by step to see if one item causes the problem.  So far I have resetup all my network/LAN DHCP settings, Wireless, IPv6, DynamicDNS, Ports forwarding.  The speed is holding.  I plan to turn on VPN, Circle and test again.  Then I will see about traffic monitor and QoS.
Message 11 of 52
Highlighted
It sounds like you and Iare both on the same boat (Titanic)
I am waiting your results to see if I have to do the same.
Yes it is painful.
Just picture this router being in a rather large business and you have to tell all the people, that the network will be down for maintenance.
It happens, I know but It just doesn't make any sense that you have to go back to default to go forward for a fix.
 I am Pending your results
Message 12 of 52
Highlighted
Apprentice
Circle and VPN are enabled and the speed is still fast.
Going to watch this for a few days before I make any other tweaks.
Message 13 of 52
Highlighted
Apprentice
@windsaga wrote:
Hi  Nightcrawler67
Would you try the FW ?
This reports as 1.0.9.13 but is newer build date? Huh?
Message 14 of 52
Highlighted
Yes, that was an old Firmware that someone had suggested to go back to.
The latest is : Firmware Version
V1.0.9.14_1.2.25
Message 15 of 52
Highlighted
Apprentice
V1.0.9.14_1.2.25
Not for sure. I now have two builds of 1.0.9.13 with different build dates. The newer one might actually have been built after 1.0.9.14 and they are all different sizes? Just curious who it was that shared this other one out?
Message 16 of 52
Highlighted
Message 17 of 52
Highlighted
I also have an update.
I threw in the towel and gave up and did a factory reset.
Before I did that I saved my config file for all my settings.
The only settings I have are
1. Wifi passwords
2. Port fwd for my security cameras, so I can view on my phone and remote computers
I did a Factory reset, tested the speeds.
I am plugged into the Netgear and the speeds were what they should be, same as my Xfinity router
So from the Xfinity router to my Netgear router to my PC all the speeds are flying 237/12
So that tells me there is something in MY cfg settings that the Netgear doesn't like, so I tested that theroy.
I uploaded my config settings that I had saved.
Speed test failed, back to the slower speeds.
I shut off VPN service
Failed.
The only other option I have is to do another factory reset and start from scratch and One by One config the router to where I had it.
This is not COOL and not Explainable
I will update when I am done
Message 18 of 52
Highlighted
NETGEAR Expert
Hi Nightcrawler67, Hoyty,
You may try below FW, it can get improve.
https://www.dropbox.com/s/gj6ri2kewbe0eg7/V1.0.9.15_20171207_fpath.chk?dl=0
BR.
Message 19 of 52
Highlighted
Ok, this may be a final UPDATE and FIX for anyone having issues.
Upgrade firmware to the latest.
Run tests
If they still fail speed tests like I am having plugged into the netgear, then prepair for a total factory reset.
I took screen shots of every aspect of my settings that I needed to keep the house network to a minimum.
What I mean is, WIFI  name and passwords
LAN and WAN settings.
Device name
Port Forwarding, etc...
I didn't want all the phones, ipads, anythign on the wifi including security cameras and also my Camera's NVR.
I wanted to just change the Netgear and not the devices
All of teh Nighthawk settings I took screen shots
It doesn't make sense that even though I performed a backup of the same exact settings didn't work when I uploaded them back after a factory reset.
It just doesnt make sense at all.
SO I did a factory reset, keeping the updated firmware.
Screen by screen I changed the settings back to where they were, manually.
Same exact settings when the speeds were slow.
I performed reboots and speed tests every change of setting
NOW, speed tests after the router
231.91 - 13.86
241.34 - 12.35
264.55 - 12.86
WOW
Fixed !
No Rhyme or Reason and I think pretty stupid, but its a pain staking task but FIXED
Message 20 of 52
Highlighted
NETGEAR Expert
Thanks for your update. ^^
Message 21 of 52
Highlighted
Apprentice
Well, when I got home the Circle app made me setup Circle all over again.  Now I am once again back to 80Mbps download speed, both wired and wireless.  Ugh.
Circle cannot keep up?
Message 22 of 52
Highlighted
I bought this router especially for my new ISP provider 500/25.
Testing speed (wired) and download is max 350Mb/s. Flashing latest fimware 1.0.9.14 and max download speed is 190 Mb/s. Shocked!!!
Google for this problem and I found here about 20 threads with this problem. People are downgrading firmware, reseting to factory defaults, not changing any options,.....- tragedy and comedy in one.
What is it? Netgear - are You a serious company? How can You release new firmware without testing? Who is creating this firmwares - students, trainees?
Please tell me which is the latest stable firmware that will provide full speed for this router?
Message 23 of 52
Highlighted
NETGEAR Expert
Hi Torecki,
You can try the trial FW, it do get improve and will also include in next release.
Message 24 of 52
Highlighted
NETGEAR Expert
Message 25 of 52
