× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 51 replies
  • 3219 views
  • 3 kudos
  • 11 in conversation
Announcements
Top Contributors
Reply
Highlighted
Re: R7000 not putting out the speeds
I have done everything you have stated.  I have decided to plug my ethernet cable from my PC to my modem and now I am getting 100+  Mbps.
Seems like I will have to wait and save up money to buy a different router from a different company; while not having WIFI.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 51 of 52
Highlighted
WOW,
I am still getting lag when streaming, and a speed test has my speeds back where they should be after all the BS I went through.
So I decided to setup QOS and make MY PC the HIGHEST priority for speed.
Its actually as FUNNY as it is SAD, that NETGEAR allows this to happen.
My Router, does a speed test under QOS,
 237.33 Mbps 11.70 Mbps
That is the speed coming into the router, according to the QOS test under .....
But speeds on my PC prior to Enabling Qos, 213.30 down 12.56 up - Still slower than the speed the router is getting.
I set my PC for the HIGHEST priority
after the reboot my pc no gets 8.92 Mbps up and 8.72 down
Are you kidding me???
YA, DONT ENABLE QOS...it DON'T Work!!!
Bottom line for a fix for this, is to buy another Name Brand router...
Netgear is doing NOTHING to fix this issue. and I know I am not alone with the problem
Linksys here I come..
Message 52 of 52
