Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 not restarting after hitting Wifi & WPS buttons
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-25
11:49 AM
2016-06-25
11:49 AM
Looking for help with my r7000. It was installed and working fine for months but my son hit the Wifi WPS buttons and now it won't restart. I just have the power & internet lights on
I should say I'm tech challenged & currently without laptop or PC. I think I installed with a laptop and wonder if I need a hard connection to fix this. I just have an iPad & iPhone right now.
I thought resetting the router thru Genie but it won't let me login. I was connected to the router with iPhone & I tried iPad too but same result.
Do I need to restore factory settings & if yes, can I install without a PC connection? I have Comcast modem & wifi.
Any hep is so appreciated.
Solved! Go to Solution.
Message 1 of 3
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-26
09:28 AM
2016-06-26
09:28 AM
I had to do a hard reset but it worked. Thank you for your advice
Problem resolved😀
Problem resolved😀
Message 3 of 3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-25
05:12 PM
2016-06-25
05:12 PM
Re: R7000 not restarting after hitting Wifi & WPS buttons
Did you remove power and reboot the router and still have the same problem? If so, then yes, do a hard reset. Wifi security password should be reset to default (which is printed on the router).
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-06-26
09:28 AM
2016-06-26
09:28 AM
Problem resolved😀
Problem resolved😀
Message 3 of 3
Announcements
