- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 reboots every 2 hours
- Mark as New
- Bookmark
- Subscribe
- Permalink
My R7000 reboots randomly every few hours. I am unsure if this is a hardware or firmware issue. I have completed the reboot and reload multiple times but it keeps coming back randomly. The router is only a few months old. Does anyone have any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Been going strong for the week. Looks like this may be the best resolution.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 reboots every 2 hours
1. try installing firmware version 1.0.9.42, factory reset it and manually re-install it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Worked for 5 hours then rebooted again. Suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If its only a couple months old, I'd start an rma with netgear. Here's why
1. your on the most stable version of the firmware
2. you could check for hardware fixes but it might void your warranty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any update on your situation? I'm having the same issue. Usually only happens at night when my kid is on his xbox and i'm streaming on netflix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reflashed back to FW 42 but it is still doing it. I am going to attempt fresh tomato and see if it helps...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far 24 hours with the new Fresh tomato firmware and going... crossing my fingers...
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I am now on my second day with fresh tomato and It has been stable (so far). A couple of things. I am a software novice so this was not simple. Flashing the software was not difficult but I blew out the username of my router in the process. No combination of username and password would work when prompted by the router (and I tried them all... trust me). After the firmware flash, I had two networks (one for 2.4 and one for 5.0) but both were unsecured an open. Upon attempt to secure them I realized what I did. I have acces to some pretty sharp software engineers so one helped me backdoor the router. I found that you could only backdoor using ssh. After finding that the firmware flash essentially cleared the username (the password was in fact admin), I was able to reset the username and password and then set up the security and rename my networks. A bit of pain but if this restores the router I am satisfied. I also learned a lot in the process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
