Reply
R7000-serial number
flyfisherman
R7000-serial number
I am trying to resolve wifi connectivity issues as well as update firm wear. However, routerlogin.net does not recognize serial number of my R7000.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
antinode
Guru
Re: R7000-serial number
> [...] routerlogin.net does not recognize serial number of my R7000.
   Why does it care?  If this is a lost-password situation, then you
might want to reset the router, and start again, using the default
password ("password").
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Factory
Settings".
Message 2 of 4
If this is for password recovery, then you may get locked into a closed loop if you left password recovery enabled but did not set up the information needed to regain control. Reset is the only way out.
It is a bug. Maybe they fixed it in later firmware.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
flyfisherman
Thank you Michael
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4394 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
