- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 slow download speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
only realized after 8 months that my R7000 router always has a download speed close to 3-5 mbps when my ISP provided me 75mbps upload/download.
I got latest firm ware updated and customer service suggested me to use channel '11' from 'Auto'. Tried that but for first few minutes it is good but in no time it again going down to 3-5 mbps download speed, I noticed my upload speed is relatively higher.
Does any one experienced the same issue?
Noticed one forum about this issue but no solution as I see it.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
--bill
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 slow download speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have similar issue...
I had Cable company upgrade my line from coax to fiber optic last weekend.
I was getting 900+ Mbps when I wire connect my system to modem.
But using the same cable, connect it to WAN port of Nighthawk, the best I get from the connected clients are ~400 Mbps.
Upload speed was ~50 Mbps. I disabled QoS upload, then I got ~350Mbps for upload speed.
I didn't have anything else connected to router (wired or wireless) for testing.
MTU is set to (default 1500)... and same on clients.
I did ping google.com -f -l 1472 (that's 1500 - 28 header) without any issue.
ping is ~7 ms
I'm using speedtest.net
Is it because NAT setting that's slowing down the the thru put and not avoidable??
Thanks!!
Ski
- Mark as New
- Bookmark
- Subscribe
- Permalink
--bill
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have read many sites with this same issue for the R7000. My ISP provides Fiber to my home with speeds up to 1Gb using PPPoE. I am unable to come close to 50% of throughput for my availible bandwidth. Currently with the R7000 inline and wired to 1 laptop I can obtain 350 Mbps of throughput. Removing the R7000 results in 750 Mbps of throughput.
I reset and configured my router as you recomended and the throughput of the R7000 did "NOT" improve. I could only attain 350 Mbps using the R7000.
I did note some of the first reviews of this router when it performed much better than I am seeing. On the following site it shows the throughput is exceptional but if you note the firmware is an old firmware version V1.0.1.22_1.0.15.
I have started looking at new routers and sadly Netgear is no longer on my list of vendors. I am not purchasing your devices because of the number of customers seeing this problem and the legnth of time you have ignored their voices with an unwillingness to resolve this issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've heard the same about the R7000 and PPPoE. It probably can't handle the decapsulation and encapsulation of the PPP headers in hardware.
Let us know if you find a wireless router that supports hardware offloading of PPPoE. I have a colleague in the same boat.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very poor support from Netgear. I have had this issue intermittently, slow on both frequencies, and on the wired ports, just suddenly, out of the blue. Port 4 actually becomes unresponsive, and does not return a ping.
The latest from Netgear, after having proved that the issue is not with the Cable modem (100Mb/s down), and is definitely with the router, either hardware or software, is that I try changing the DNS to 4.2.2.2!!!
Clearly they are not listening, and really dont care. This is a useless router as its stands Off to buy an Asus, - I cant wait indefinitely until Netgear get serious about fixing this one.
I have no idea how it gets recommended on any site. Its that bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I will thanks you.
In the interim, I beieve I may have found the solution to my isse, that may be helpful to others.
I have been swapping routers bertween the R7000 and an ASUS RT AC66U. I joticed that after a while they both exhibited this problem (though the wired ports on the ASUS were not affected) and monitored closely for a few more days. I saw a time relationship to the problem, - it would happen ar certain times, mainly, but nt always the evening, so being on a Cable network, I monitored the cable feed; there was no drop in speed at thre cable provider side, the speed drop was associated with the router.
Evetually, after monitoring connected clients, one in particular, which had a private MAC address seemd to be connected at the times I had problems.
Turns out it was a Kindle, and my wife was trrning it on, and reading, and the wirelss was on. I turned the wireless off on the Kindle, and the problem disapperared. I went from arounf 2Mb/s down and about 1 up to 69Mb/s down and 4.2 up.
I googled KIndle devices and found that this is very common, mainly with the Kindle Fire; our Kindles, - we have 2 are Kindle Touch models; the other Kindle when powerd on with wireless on, did not show the same issue. I have reloaded the suspect device, and have left its wireless off.
If you have these symptoms, check is you have a Kindle, especially a Fire, and disable its wireless connection. Amazon may have fixes, - they have none for my version.
I will continue to monitor, - the R7000 is now in service, and I will report back. Im not sure exactly what the Kindle was doing, but this precise effect is very common, and can be easily found with a Google search.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I addition to the note I added re the Kindle, I wanted to say that the ASUS CPU was 100%, and the memory usage was 95% during the time the the slow performance/connected device issue was in progress. This was very helpful in troubleshooting.
Is there a way to monitor these parameters in the R7000?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @williebabeham,
This feature is not available with the router. This is a great idea and you can offer this suggestion in our Idea Exchange board.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my case, there was Linksys WET610N on my LAN freaking out. Turning off wifi at the router restored my expected speed. Turing it back on and then disconnecting wireless clients one-by-one led me to the WET610N.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
