- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 wifi and lan crash
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi,
we were facing some random crashes with our previous router, so we decided to change to R7000.
But crashes still occurs.
Symptoms :
Wifi is still present but you cannot connect to it.
Full office Ethernet LAN isn't working (star switches network)
Unpluging every cables (WAN/LAN) from router does not change anything
Direct connection from my pc to the router without any other cable plugged, dhcp isn't working, and can't ping the routeur static address being in static also.
After reboot everything is fine
We had the exact same behavior on the previous router
Data :
Router is using a static route on WAN side to forward traffic to the ISP modem
ISP modem hasn't changed and is SDSL modem from SFR (France).
Router is the DHCP provider
We tried to modify wiring to desengage network/server traffic from router, but it still behave the same way, even if crashes feels to occurs less frequently.
Router is up to date.
Could someone advise us some tests ?
Are there some logs, system wise, on the router ?
