- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 wifi is not working correctly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I received a bunch of security e-mails sayign to upgrade to firmware Version V1.0.7.6 and a few hours prior to that (1600 est) I had no wifi. None of the devices in my house can connect and no wifi is showing from my router. I have tried everything and still can't get it working again. I did absolutely nothing to change internet access and did nothing with the router until I updated the firmware. Even when I go to routerlogin.net it shows all my guest networks are running, but then I click on the Advanced tab and it shows a green check mark by Router Info and Internet Port, but Wireless 2.4g, 5g, Guest Network 2.4g and 5g have red X next to them. Any help would be greatly appreciated!
Thanks,
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Oddly enough 20 minutes after the factory reset it started working. Very odd, but it is now working! Thanks for the response anyway.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: R7000 wifi is not working correctly?
I tried rebooting the router, I reset to factory, I tried the radio signal. About all I could find to try to get it working. Not a router guru, so don't know much else to try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Glad it's working for you!
