Reply
R7000 will no longer show 5Ghz while trying to connect with devices
wishbrandhacker
I have no idea why but all of a sudden my router will no longer show the 5Ghz channel when trying to connect a device and all the devices i had connected to the 5Ghz had to be re-connected and will only connect to the 2.4Ghz. Does anyone else have this problem and have you been able to fix it??
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 6
realicetea
Re: R7000 will no longer show 5Ghz while trying to connect with devices
I have the exact same problem. 5Ghz is dead. Get it working by renaming the SSID... but as everything starts connecting again... it dies
Model: R7000|AC1900 Smart WIFI Router
Message 2 of 6
Guru
do you have the R7000 or the r7000P? you put one in the title and the other in the signature.
What firmware version is it on?
Are you using smart connect?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 6
wishbrandhacker
R7000P, it has the latest firmware and I am not using smart connect
Message 4 of 6
Guru
What actual version of firmware are you on?
That's key with the R7000P. Sometimes people aren't truly "on the latest" as well as it changes or isn't always the best.
Some r7000p's struggled with the firmware that has armor (even disabled). Its why we ask.
Message 5 of 6
wishbrandhacker
I'll have to get back to you on that when I get home. The anywhere access isn't working right now. SMH
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 221 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
