Reply
R7000 will not work with new modem
sodapapa
I purchased a Arris modem Model SB6183. It only has one Ethernet  connection so I can't hookup my router.How do I hook it up?
Thanks
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
antinode
Guru
Re: R7000 will not work with new modem
> [...] SB6183. It only has one Ethernet connection so I can't hookup
> my router. [...]
   Huh?  "so"?  "can't"?  Why, exactly?  What, exactly, is stopping you?
What, exactly, are you connecting to what, exactly?
> [...] How do I hook it up?
   Here's a radical concept which works for some people:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.
Message 2 of 5
labatt
Mentor
Modem has 1 Ethernet port. The r7000 has one WAN Ethernet port. Do not understand why you cannot connect the two together. Need info on what you are trying to do.
Modem CM2050V
Message 3 of 5
Thanks
Visit the support pages for your R7000:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
The Quick Start Guide is a good place to start.
Remember, if you are replacing a modem, then you will need to reset the router too. It needs to forget any settings inherited fro the previous modem.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 5
antinode
Guru
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 158 views
  • 0 kudos
  • 4 in conversation
Announcements
