- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
R7000 wireless not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 wireless not working
I tried everything from factory reset to pressing buttons and enable/disable in Genie... nothing works. I spent hours looking for an answer in the Netgear support community without any success. Please help me
- Mark as New
- Bookmark
- Subscribe
- Permalink
I fixed my problem by resetting to factory settings. I initially tried saving my settings, but restoring them after factory reset just brought the problem back, so I had to reset again. Then I laboriously (JK, it took less than 10 minutes...) re-entered all the items I was trying to restore. Still working well weeks later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue with my R7000 router. It works with a wired connection (Ethernet cable) but does not work with wifi. As with the screenshots shared by CurryFoundation; I have the same view on the router homepage. Tried all these-
- Factory Reset ;
- Hard reset (with the reset button)
- Changed the wifi SSID and pwd
- Tried checking and unchecking the "Wireless Router Radio" checkbox
- Downgraded firmware to V1.0.4.30 .
Any other suggestions that may get the WiFi working?
Thanks!
~Ganesh
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a hard reset, then restored my settings from the saved file. No love, but then I repeated the reset and it worked. Manually restored my settings one-by-one and it still works. Sorry this didn't work for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just got it working. Here's what I followed.
- Hold hard reset for 60 sec
- Uplug the power connection for 60 sec
- Reconnect power cable & wait for lights to turn white
Now all devices are back online for the past hour. Fingers crossed for continued connectivity.
- « Previous
- 1
- 2
- Next »
