Reply
R7000 with Virgin Superhub, speed fluctuating massively.
Stueybuk
Hi all,
Just set up my new router, Superhub 2ac in modem mode and all was good. Was getting 220Mbps to my laptop via wifi and was really impressed. An hour later this had dropped to 160, thought this maybe general fluctuation until I connected this morning and was at 2Mbps. Rebooted everything and got back up to 60 but nowhere near the initial speed.
Can anyone recommend any checks I can perform ? I did upgrade R7000 to latest firmware after the initial test.
Thanks in adbance,
Stu
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 5
JamesGL
Master
Re: R7000 with Virgin Superhub, speed fluctuating massively.
Hi Stueybuk,
1. What is the speed when wired to the router?
2. What is the speed when wired to the modem?
Message 2 of 5
Stueybuk
Thanks for the reply James. Sorry for the stupid question, but how do I check the speed when wired to the modem ? Do I need to put a static IP on PC as the modem will not allocate an address ? or do you mean put the superhub back to router mode and test ?
Cheers,
Stu
Message 3 of 5
JamesGL
Master
Hi Stueybuk,
Just connect the computer directly to the modem and the modem should give an IP address.
Message 4 of 5
Stueybuk
Thanks, I'll try that tonight.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5087 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
