Orbi WiFi 7 RBE973
Reply
R7000
jvderaa
R7000
I pushed the wi-fi button by mistake instead of the connect button for adding wi-fi extender now it will not turn back on
Message 1 of 4
Accepted Solutions
jvderaa
Re: R7000
I ended up unplugging over night then it worked the next day thanks
Message 3 of 4
All Replies
ElaineM
NETGEAR Employee Retired
Re: R7000
Welcome to the community, @jvderaa
Did you try pushing it once more 3-5 seconds?
After pushing the WiFi button, the 2.4GHz and 5GHz lights should turn on.
If not, the only option is to factory reset the router.
After factory reset, you will have to reconfigure the router to get it up and running once again.
Message 2 of 4
jvderaa
Re: R7000
Message 3 of 4
ElaineM
Re: R7000
You're very welcome. Thank you for the update!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1457 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
