Reply
R7000
bostondesignz
Follower
R7000
I have an R7000 wifi router that is connected to a CM500 extender. I can't remember the password for the extender. Is there any way to change it through the R7000?
I can't log in to the ext to change the password.
Message 1 of 5
myersw
Master
Re: R7000
I believe the CM500  is a modem not an extender?  In any case probably the only recovery is to reset the CM500 then reinstall/configure.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 5
IrvSp
Master
Re: R7000
The CM500 is a MODEM, and most modems are under the control of the ISP (even if you own it). They control what firmware is on it, and might have, even in this case changed settings and passwords. Have you tried contacting them?
Message 3 of 5
Re: R7000
Adding to what other say, there is a manual for the CM500 somewhere at the end of this link:
>>>> CM500 | Product | Support | NETGEAR <<<<
Help for that is best sought in the approiate bit of this forum:
Cable Modems & Routers - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 5
myersw
Master
Re: R7000
I own a CM500V connected to Comcast. I can do everything to it including reseting in the UI. Only thing I cannot do is update the frimware. I can set or change PW as well.
--Bill
Tesla > Edison
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 687 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
