× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 1 reply
  • 102 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
R7000
Why when I go to the reset password recovery and input my serial number I cannot see the connect function ?
Message 1 of 2
Highlighted
Prodigy
Re: R7000
Because the password recovery is broken in the firmware along with other issues,
If you do not know th password the only way to fix is to reset the router then the defaults will work.
Modem CM1150V
Message 2 of 2
