- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Do routers lose range over time? R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does a ten year old router lose range quality over time? Will a new model better meet todays wifi needs? Experienceing some buffering at extended range on Roku device.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware Version: V1.0.11.110_10.2.100
Conducted Speed Test under the QOS Tab.
Router is wired to PC and sends wireless wifi to all other devices.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
What modem do you have?
What firmware is on the R7000?
the r7000 isn't known for the best firmware. The agreed upon stable version is the 1.0.9.42 version. You could try installing that, factory reset the router, and then see how it works.
What do you consider "at range" to the roku?
Are you connecting via 2.4ghz or 5ghz to the roku? 2.4ghz is much much slower but broadcasts further and through more materials. In my area, its pretty much worthless for streaming because it also suffers from interference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
Currently using Firmware Version V1.0.10.90_10.2.90
Using 2.4 ghz for longer range.
Roku connection is Fair located opposite side of house.
Modem was just replaced by Spectrum (Charter)
Latest Speed Test:
Latest test result: Fri Oct 2 13:07:52 2020 | |
92.42Mbps | 11.78Mbps |
Download / Upload
Thank you for the insight!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
Why? It's not the latest, or the best.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
Checked for firmware update under Advanced / Admin / Router Firmware Update Assistant and ended up with:
Firmware Version Check |
No new firmware version available. |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
Updated Firmware saw a 38% increase in internet speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000
> Updated Firmware [...]
To which version?
> [...] saw a 38% increase in internet speed.
"saw" how, exactly? Wired or wireless? Measured what, how?
Plenty of things can affect wireless speed and range, including
interference from other nearby wireless-network radios.
- Mark as New
- Bookmark
- Subscribe
- Permalink
