Reply
R7000P 2.4G not broadcasting
NetUSERW
Tutor
The R7000P stops broadcasting 2.4G.   The 5G works just fine.
I downgrade the firmware to 1.2.0.22, factory reset, reconfigure, still the same.
Updated to the latest firmware 1.3.1.44, still the same.
Anyone have the same issue?   Help appreciate it!
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: R7000P 2.4G not broadcasting
Is the 2.4 ghz light on the front of the unit? does it say its active in the settings?
DarrenM
Message 2 of 4
NetUSERW
Tutor
Yes, both 2.4 and 5 ghz activated in the settings.   Both LED lights are on in front of the unit.
Message 3 of 4
DarrenM
You may want to contact support could be a hardware issue.
https://www.netgear.com/support/contact.aspx
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 753 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
