Reply
R7000P Assigning IP problems
Sickonblues
I'm trying to assign a static IP address to a device.   For example, I try to assign 192.168.1.10 but when I apply it, I get the message "IP address should fall within the DHCP range".  My range is set from 192.168.1.2 - .254 so that shouldn't be a problem.  Similarly if I try to assign an IP address that is currently in use to the DMZ I get an error saying the IP address is not valid even though it is currently in use.  Port forwarding also doesn't work.  When I try to apply my settings, nothing happens.  I just set this router up.  It is brand new out of the box but I'm stumped.  Any advise?
Message 1 of 4
JoseAndres041
Luminary
Re: R7000P Assigning IP problems
What is your router's current firmware version?
Message 2 of 4
antinode
Guru
 > R7000P [...]
   Firmware version?  Connected to what?  What is the LAN IP address of
the R7000P, "192.168.1.1", or something else?
> I'm trying to assign a static IP address to a device. [...]
   No, you're trying to reserve a dynamic address on (the DHCP server
on) your router.  A static address is configured on the device itself,
not on the router.
   What's the IP address of the computer, which is connected how to the
R7000P?
> [...] I try to assign 192.168.1.10 but when I apply it, I get the
> from 192.168.1.2 - .254 so that shouldn't be a problem. [...]
   Apparently, either you or the R7000P is confused.  If it's the
R7000P, then a settings reset (and manual reconfiguration) might help.
Message 3 of 4
Sickonblues
It was on the most recent firmware, but I was able to resolve the issue by flashing the previous firmware to it.  A manual reset did not work.  After I reflashed the firmware, it allowed me to make my desired changes including reserving an IP address (not a static IP, got it).  It has since been flashed back to the most recent.  I would say there was some sort of firmware corruption that occurred when it downloaded the firmware update during the intitial setup.  Guess it wasn't me who was confused.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 525 views
  • 0 kudos
  • 3 in conversation
Announcements
