Discussion stats
  • 1 reply
  • 684 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
R7000P IPV6 issues
As the subject states, I've enabled IPV6 (Confirmed through ISP to be working), and I auto detect / auto config since I don't have too much experience manually inputting the information. I get both a LAN address and a WAN address but when I do the IPV6 test, it says unsupported. I've looked around and noticed a lot of people saying these routers are just so faulty and WILL NOT do IPV6. I'm wondering if anyone has any suggestions or if they've figured out a fix. I'm on the latest firmware. 1.2.0.22_1.0.78
I rolled back to earliers and did the 30-30-30 resets and still had/have the issue. I'd prefer not to get a different router, but if that's really what I have to do, I can't exactly say no if NG hasn't addressed and/or fixed the issue.
Message 1 of 2
Highlighted
Re: R7000P IPV6 issues
What sort of IPv6 does your Internet service provider use?
Is it one that the R7000P supports?
Maybe you could tell us which ISP it is. I hope it isn't BT.
Re: IPV6 with BT Infinity - NETGEAR Communities IPV6 with BT Infinity - NETGEAR Communities
IPV6 D7000 not working properly - NETGEAR Communities
D7000 Nighthawk no IPV6 support with BT Infinity? - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
