Reply
R7000P VPN Question
Erik88
R7000P VPN Question
I had a question about the VPN functionality of the R7000P Nighthawk Router. I know that there is a 3 simultaneous VPN connection limit. I was curious however if I can have two simultaneous VPN connections of the same class of client for example two IOS devices. When attempting to connect both my iPad and iPhone to my VPN network, I noticed that only one of them could connect successfully. Is there a way around that limitation or is it only happening to me?
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 5
Guru
Re: R7000P VPN Question
what vpn are using?
is it an aftermarket 3rd party provider?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 5
Erik88
Hi. If you're referring to the VPN Client, I use Open VPN.
Message 3 of 5
Erik88
Bump
Message 4 of 5
Guru
I've never used open vpn so I'm unsure of their specifics.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 234 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
